CAD tip CAD tip # 9911:
Question
You can use the standard Copy/Paste functionality to transfer your DWG drawing from AutoCAD to Word (Excel, or other Office application) including any special objects (e.g. AEC-walls), lineweights, texts, etc.
In AutoCAD use the function Edit/Copy (Ctrl-C), in Word then Edit/Paste (Ctrl-V), eventually Paste As. For transferring line widths first enable the lineweight display (the LWT button in AutoCAD status bar). After you paste the drawing, you can double-click on it in Word to edit it in AutoCAD. You can use more advanced transfer options with the BetterWMF utility (see Download).
Do not use the Word function Insert/Image/From file.
You can also use the WMF export from AutoCAD - WMFOUT.
For background issues - look for tips to "background WMF".
ACAD14ACAD2000ACAD2006ACLTADTMap
100% WinCAD
17.7.2014   38789×   FAQ   Rookie
this tip shared by ARKANCE experts applies to: AutoCAD 14 · AutoCAD 2000 · AutoCAD 2006 · AutoCAD LT · AutoCAD Architecture · AutoCAD Map 3D ·
Tip 8703:File formats compatible with Autodesk BIM 360 Glue.
Tip 6254:How to convert an AutoCAD DWG to CorelDRAW CDR file?
Tip 4660:Safety signs for AutoCAD.
Tip 3812:Beware of using Copy/Paste to copy AutoCAD entities inside drawings.
Tip 3004:How to export a drawing in hires vector file format from Autodesk Inventor?
Back    All CAD Tips
Categ:
