  Visitors: 5337
CAD tip CAD tip # 11522:
How to create 3D splines in Fusion 360 - e.g. for pipe axes?
A - answer You can 2D spline curves to 3D by moving their control points in Z-axis. But if you want to create 3D splines directly, enable the appropriate option in Fusion 360 preferences (in the menu under your login name).
In General > Design check (enable) the option "Allow 3D sketching of lines and splines":
You can use osnaps and constraints to existing 3D model geometry while drawing 3D splines. You can then use the resulting spline e.g. as an axis to create a 3D pipe (Create > Pipe).
Fusion360
9.7.2017    11554×
Prices - CAD eShop:
applies to: Fusion 360 360 ·
Tip 13595:How to transfer 3D model incl. toolpaths from Inventor CAM to Autodesk Fusion 360?
Tip 10791:How to force Fusion 360 to use DirectX 9 or 11?
Tip 10219:Can Autodesk Fusion 360 make use of multicore CPUs?
