CAD tip CAD tip # 10709:
Question
You can use the script ImportSplineCSV in Autodesk Fusion 360 to read-in an outline profile or other spline curve defined by XYZ coordinates of its individual vertices (or just points).
This script can be invoked with the top menu File > Scripts and Add-ins (or press Shift+S). In the dialog then select the predefined script written in the JavaScript or Python languages, called "ImportSplineCSV" and click Run. Then just choose your CSV file (e.g. exported from Excel) containing the point coordinates and Fusion will generate the respective spline curve.
Data in your CSV file must be comma-separated, with "." as decimal point separator, and all 3 coordinates X,Y,Z must be used (Z can be 0).
To load CSV files from localized Excel versions (e.g. German - semicolon delimiters, decimal comma) or 2D (XY) only CSVs, use the globalized script ImportSplineCSVg - see DL Download. Unpack its folder to other Fusion scripts - e.g. to:
C:\Users\USERNAME\AppData\Local\Autodesk\webdeploy\production\b27b8...57da\JavaScript\Samples\
or rather to
C:\Users\USERNAME\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\Scripts\
and add the .js file to "My Scripts" with "+".
The variant ImportSplineCSVm can import multiple profiles at once - delimited by an empty line in the CSV file.
The variant ImportPointsCSV reads the coordinates as Points, not Splines.
Fusion360
22.1.2016   35969×
this tip shared by ARKANCE experts applies to: Fusion 360 ·
Tip 15164:7 types of installation of the CAD/CAM application Autodesk Fusion.
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14941:Fusion: The code execution cannot proceed because Qt6Widgets.dll or acge230.dll was not found.
Back    All CAD Tips
Categ:
