CAD tip CAD tip # 11896:
Question
With the LISP add-on utility XLSparam for AutoCAD, you can control dimensional parameters of dynamic block, parametric constraints and other properties of drawing objects in your DWG files, by data from Excel XLS tables, from data extraction tables, or from manual tables in your DWG.
XLSparam links geometric parameters of dynamic blocks and constraint parameters with Excel XLS tables. In this way you can export parameter values to Excel and subsequently read the changed values back into your DWG drawing. You can also establish links between the values of dyn.block parameters (or other object properties) and given tables, and then drive these parameters by changing the tables (local drawing tables or datalinked Excel tables or dynamic dataextracted tables).
XLSparam brings more intelligent parametric behavior to your DWG drawings. Dimensions, rotation, or other properties of drawing objects can be driven by complex computations performed from your Excel worksheets. Entities can dynamically react to the results of BOMs (data extractions) from the same or from other drawings. By changing a single parameter in a table you can influence multiple objects at once.
Since version 1.1 you can also export, change and re-import visibility states.
How to use XLSparam:
More information and Trial download - see XLSparam.
ACADCivil
28.5.2018   31778×
this tip shared by ARKANCE experts applies to: AutoCAD · Civil 3D ·
Tip 15003:Using lookup table to control parameters of a dynamic block - clock.
Tip 14721:Pixel fonts and "cube" styled texts in Fusion.
Tip 14714:Why is Fusion suddenly putting apostrophes in my text?
Tip 14699:How to add an attribute to all visibility states in a dynamic block?
Tip 14604:QRcode - dynamically generated QR codes in AutoCAD.
Back    All CAD Tips
Categ:
