Over 1.091.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 7444:
Question
AutoCAD supports two basic types of fonts - a) its own native SHX fonts and b) Windows system TTF (TrueType) fonts.
a) A SHX font is installed just by copying the respective .SHX file into the AutoCAD Fonts folder - e.g. C:\Program Files\Autodesk\AutoCAD 2014\Fonts. AutoCAD also support PostScript fonts but PostScript fonts (.PFB) have to be first compiled to SHX using the COMPILE command.
b) A TrueType font (.TTF) cannot be added to AutoCAD just by copying - this Windows system font has to be installed into Windows. In the "Windows Control Panels" (WinXP/Vista) choose Fonts and in the File menu select Install new font. In Windows 7/8/10 just drag the TTF file to this Fonts window or right-click on the TTF file and choose Install.
After that you can use the new font in the AutoCAD STYLE dialog.
ACADACLTADTCivil
12.7.2010
295702×
