  Visitors: 6831
CAD tip CAD tip # 13177:
How to list Civil subassemblies used in the DWG file?
A - answer An overview of assemblies and subassemblies in the current DWG drawing can be found in the palette Toolspace > Prospector > Assemblies:
If a component of a subassembly is missing on a given computer, a missing component warning will be displayed when opening this .DWG file:
One or more subassembly .Net classes could not be found. Check Event Viewer for more information. Continue?
or
One or more subassembly macros (or .Net classes) could not be found. Check Event Viewer for more information. Continue?
After starting the "Event Viewer" (SHOWEVENTVIEWER) you can see more detailed information:
You can find more information about parameters and location of subassembly .DLL files by right-clicking on the subassembly in the Prospector and selecting the "Properties" function - on the "Parameters" tab:
Civil subassemblies and their codes are by default stored in the folder C:\ProgramData\Autodesk\C3D 2022\enu\ (e.g. C3DStockSubassemblies.dll), resp. in its subfolders Subassemblies and Imported Tools. Any missing subassemblies (.PKT) can be imported using the IMPORTTOOLS command.
If you want to display a list of all defined subassemblies in the current DWG drawing, including their stored DLL paths, use the freeware utility ListAssemblies. You can download it from Download, load it into your Civil with APPLOAD and run it by typing the ListAssemblies command. Select "all" and the command will output an alphabetically sorted list of used subassemblies, incl. the paths to their DLL files and whether that DLL is available on your PC.
Note: by setting the LISP variable (setq _NOStockSubAssy T) you can avoid listing of internal subassemblies from C3DStockSubassemblies.dll
Civil
2.1.2022    11186×
Prices - CAD eShop:
applies to: Civil 3D ·
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 12977:Easily find CAD/BIM document references (including missing ones) - Reference Explorer
Tip 12361:Seamlessly connected images by irregular clipping in AutoCAD (or LT).
Tip 8230:3D PDF output from AutoCAD, Inventor or Revit.
