I work on a shared computer and I need to auto-logout from my Autodesk account after closing the CAD application I worked in (Fusion 360, Infraworks, BIM 360, Team, Desktop App, etc.).
The common (for all Autodesk apps) login to the Autodesk account for a given user on a given computer workstation (his/her user profile in the operating system) is stored in the LoginState.xml file. This file is located in the folder:
- Windows:
C:\Users\USERNAME\AppData\Local\Autodesk\Web Services
- MacOS:
Macintosh HD > Users > USERNAME > Library, resp. ~/Library/Application Support/Autodesk/Web Services
So you can just log-out from any single Autodesk application to log-out completely. For an automatic log out, you will need to delete this file - e.g. using a "logoff-script" (see the Group policy editor, GPE), or at a given hour using the Task manager, etc.
Fusion360InfraworksA360BIM360Team
* CAD
18.10.2019
24591×
