CAD tip # 11018:
applies to: Inventor 2017 · |
Tip 14048: | List of disks, CD-ROM drives, USBs and other disk functions for LISP. |
Tip 14033: | Clipping blocks, images, curves, xrefs - everything, into any shape |
Tip 13900: | How to convert truecolor color hue to the nearest AutoCAD ACI color? |
Cannot exit AutoCAD with the Windows "X"-button.
How to create an axis of two curves? (average curve) « | » How to select a DWG object by its internal ID, its "handle"?
