  Visitors: 4485
CAD tip CAD tip # 10195:
How to mirror objects with automatic deletion of the originals?
A - answer If you want to use the command MIRROR without the deletion prompt, automatically deleting the original (source) entities (no Yes/No prompt), you can prepare your own version of the MIRROR command.
Create a new command in the CUI dialog and assign the following menu macro to it:
^C^C_select;\_mirror;_p;;\\_yes;
Then map this new command to a new icon or keyboard shortcut and you can use it to quickly mirror drawing objects without making copies of the objects in the DWG.
ACADLT
4.2.2015    9789×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13358:Restore the last deleted entity in the DWG.
Tip 12237:UnfoldRS - unfold 3D surfaces to 2D in AutoCAD.
Tip 11404:Operations with attributes inside a block - fields.
Tip 10307:Easy mirroring of selected objects around their axis/center.
Tip 9644:How can I mirror my drawing without mirroring the blocks (symbols)?
VRMLout More info
