CAD tip CAD tip # 6660:
Question
If you need to simplify a complex 3D object formed by a high number of faces, you can use the ProOptimizer tool in 3ds Max (or 3ds Max Design) 2010 and higher.
The optimization of 3D objects can be invoked either through the "ProOptimizer" modifier - for selected objects in your scene, or as a batch optimization tool ProOptimizer, which can simplify in one go all .max and .obj files in a selected folder.
This batch tool can be run from the Utilities panel. Click on the button "More..." and in the list of utilities choose "Batch ProOptimizer". In the panel then click on the button "Batch Optimization" and in the dialog of this utility select he input and output files and a number of parameters controlling the method of optimization.
ProOptimizer
The ProOptimizer tool reduces the number of vertices (faces, polygons) in 3D objects while preserving the object’s appearance. Optimizing objects can reduce a scene’s memory requirements, simplify modeling because objects have fewer faces, and improve the speed of viewport display and rendering time.
max2010
5.5.2009   36307×
this tip shared by ARKANCE experts applies to: 3ds Max 2010 ·
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14833:CAD formats supported in Autodesk VRED 2026.
Tip 14820:3ds Max won't import terrain from Civil 3D.
Tip 14799:7 quick methods to upload your project to Autodesk Docs (Forma Data Management)
Tip 14471:What is the Golaem app included in the Autodesk Media and Entertainment Collection?
Back    All CAD Tips
Categ:
