Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7541:
Question
We recommend to use specialized visualization tools to create photorealistic animations of 3D scenes - e.g. Autodesk 3ds Max Design.
However, if you need to make a quick animation of a walkthrough or fly-by in your 3D scene in a DWG file (e.g. around a house or through rooms of a flat), you can also record the interactive commands 3DWALK or 3DFLY.
First you need to add the Animation panel to your AutoCAD ribbon interface (one-time operation only):
  • Switch the AutoCAD workspace to "3D Modeling" and start the CUI dialog.
  • In the tree hierarchy, select the item ACAD > Ribbon > Panels > Render - Animations (the Animations panel will show up in the top right pane). Note: the ACAD tree may be hidden as a "Partial customization file".
  • Reselect this item with your right mouse button and choose Copy from the context menu.
  • Go up in the tree to the item ACAD > Ribbon > Tabs > Render, select it with the right mouse button and choose Paste in the context menu.
  • Leave the CUI dialog with OK.
The ribbon tab Render now contains the Animations panel.
Animations panel (CZ version)
Switch to the Realistic visualization style. Use the WALKFLYSETTINGS command (or the "trampled airplane" icon in the Animations panel) to set the walkthrough parameters - step size.
In the Animations panel, select the command Walk (3DWALK, the "footstep" icon). In the "Position locator" palette, tune up the view parameters and the initial shot. Do not terminate the Walk command.
Locator palette (CZ version)
Now click the round button "Record animation" in the Animations panel. From now on, all your interactive walk motion is recorded as a video. You can move through your scene using the mouse cursor, or with the W-A-S-D navigation keys.
By pressing the square button "Save Animation" (the same panel) you launch the dialog for the animation output file - you can set its name (Animation settings), it format (AVI, MPG, WMV, MOV), resolution and frame rate.
For older AutoCAD versions, use the Tip 5212.
ACAD2011ACAD2010ACAD2009
3.9.2010    47385×
applies to: AutoCAD 2011 · AutoCAD 2010 · AutoCAD 2009 ·
Tip 11464:How to make a fast Inventor Studio animation without rendering?
Tip 5212:How to record a walkthrough animation in AutoCAD 2007?
Tip 1287:How to make an AVI animation of a reasonable size from Inventor?
Back    All CAD Tips
Categ:
