New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip # 7901:
Question
In AutoCAD, you can redirect the created backup files (.BAK) of your DWG drawings to another specified folder (a BAK directory) with the Express Tools command MOVEBAK.
If you have Express Tools installed, you can also just set the environment variable "AcetMovebak":
(setenv "AcetMovebak" "C:\\MyBackups\\")Saving of BAK files during drawing Save is controlled (yes/no) with the ISAVEBAK variable.
ACAD
*CAD
9.4.2011
22471×
applies to: AutoCAD ·
