CAD tip CAD tip # 7038:
Question
If you need to replace only some instances (references) of the given block with a new block, you cannot use the standard functions for block replacements (BLOCKREPLACE, INSERT, etc.) - these functions modify the definition of the block and so they influence all its references (insertions).
To replace only selected occurrences of the given block in your DWG drawing you can use the free LISP utility CADstudio RIblock - see DL Download.
The RIblock command prompts for the name of the replaced block (or for picking its sample), you can select the references of this block (to be replaced) and then you specify (by picking or by name) the new block. This new block will replace the selected references of the original block. Possible attributes with the same name (tag) can be automatically transferred from the replaced blocks.
In AutoCAD Electrical, you can also use the AESWAPBLOCK command.
ACAD
4.11.2009   33907×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 15080:How to replace internal blocks with external blocks (XREFs) in AutoCAD LT?
Tip 15017:AutoCAD Drawing Cleanup Utility - a standalone tool to purge your DWG files.
Tip 14527:Search/Replace texts in Inventor drawings - iLogic.
Tip 14402:What is the difference between the BLOCKREPLACE, BREPLACE, REPLACEBLOCK, RIBLOCK and BLKREDEF commands?
Tip 14361:Extended ATTOUT/ATTIN for block attribute management in Excel (also for LT).
Back    All CAD Tips
Categ:
