New CADforum look launched.
Over 1.084.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 10321:
Question
Autodesk 3ds Max since version 2012 can save scenes to (typically 3) older .MAX file format versions. This option ("Save As Type") is offered in the commands:
  • Save As
  • Save Copy As
  • Save Selected
  • Container > Save As
You can save to the following versions:
  • 3ds Max 2012 can save to versions 2010, 2011
  • 3ds Max 2013 can save to versions 2010, 2011, 2012
  • 3ds Max 2014 can save to versions 2011, 2012, 2013
  • 3ds Max 2015 can save to versions 2012, 2013, 2014
  • 3ds Max 2016 can save to versions 2012, 2013, 2014, 2015
  • 3ds Max 2017 can save to versions 2016, 2015, 2014
  • 3ds Max 2020 can save to versions 2019, 2018, 2017
  • 3ds Max 2024 can save to versions 2023, 2022, 2021
  • 3ds Max 2025 can save to versions 2024, 2023, 2022
3dsmax
17.5.2015    20709×
applies to: 3ds Max ·
Tip 14183:PLKangles - display/check kink angles in polylines.
Tip 13911:How to print all sheets at once from Inventor?
Tip 13844:With which subscriptions do I get Autodesk Drive cloud storage as a bonus?
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13541:Using Twinmotion from Revit to visualize other types of 3D scenes.
Back    All CAD Tips
Categ:
