  Visitors: 8225
CAD tip CAD tip # 10051:
How to save from AutoCAD or Inventor to Dropbox, Google Drive or OneDrive?
A - answer Windows applications, including CAD applications AutoCAD, Inventor or Revit, allow to save to virtualized disk drives or to synchronized folders of cloud storage services. But it is much more convenient to use directly the similar cloud service by Autodesk - A360 Drive (see the ribbon "Autodesk 360" in AutoCAD). This service supports ao. automatic publishing of updates, collaboration and reviews of drawings (design feed), and first of all a full-fledged online viewing and editing.
To setup direct saving to cloud storage, use either virtual disks created by a client application supplied for the specific cloud service (creates disk drives such as "Autodesk 360", "Dropbox", "OneDrive", "SkyDrive", "GoogleDrive", "Disk Google", "ZumoDrive" etc.), or you can just map the specific local folder to a virtual disk - this local folder is then automatically (with the client tool) synchronized with the given cloud storage service.
An example of mapping a disk drive "X:" using a DOS command - e.g.:
SUBST /d X:
SUBST X: "C:\Users\[username]\Documents\Dropbox"
Then just save your CAD documents to the disk "X:". A disk drive or folder can be also added to the Favorite bar (Places panel) on the left in the Open/Save dialogs in AutoCAD (right-click > Add current folder):
Skydrive - AutoCAD
Similarly, you can add a new disk or folder in Revit using the button Tools > Add Current Folder to Places:
Skydrive - Revit - favourites
ACADInvRevitCivil
17.10.2014    17038×
applies to: AutoCAD · Inventor · Revit · Civil 3D ·
Tip 13844:With which subscriptions do I get Autodesk Drive cloud storage as a bonus?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 12667:How to free up space in the local cache of Desktop Connector?
Tip 12314:How to display OBJ models including textures in A360?
