CAD tip # 9609:
applies to: AutoCAD · |
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
Tip 13504: | How to add own commands to AutoCAD custom palette? |
Tip 12760: | Replace texts with blocks of the same name - Txt2Ref. |
How to add a hyperlink/comment to an entity using LISP?
