New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 7171:
Question
For renderings, for screen-captures of your drawings, or other similar actions you may need to fix the size of the document window (DWG drawing) in the main AutoCAD application window. To set the window size to a specified number of pixels (width + height) you can use the following simple LISP code (change the size parameters as needed):
;Sets drawing window size
;by CADstudio.cz
(vl-load-com)
(setq sizer_actdoc (vla-get-activedocument (vlax-get-acad-object)))
(vla-put-width sizer_actdoc 1000);W=1000px
(vla-put-height sizer_actdoc 800);H=800px
Copy the code via copy/paste, or save it to SIZER.LSP and load it with APPLOAD, or assign it to a new AutoCAD menu icon. The function changes the window size of the current document (even a maximized window).
You can also use the interactive version of SIZER.LSP - see Download
ACAD
20.1.2010    16943×
applies to: AutoCAD ·
Tip 14359:Automatic macro execution when opening a CAD file (AutoCAD, Inventor, Max, PowerMill)
Tip 14328:How to verify entitlement of an application from Autodesk Apps using LISP?
Tip 14268:How to set the background mask color to BYLAYER?
Tip 14163:How to select DWG texts containing a certain number of characters?
Tip 14063:How to get week day and week number from a given date.
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
