CAD tip CAD tip # 7502:
Question
The history of UNDO / REDO allows to undo and redo only commands in the sequence in which they were performed.
But in case of undoing the erase function (either the ERASE command or the implied erase after the BLOCK command) you can skip the latest performed commands in the series and revert (undo) directly only the erase operation - even when it was followed by other commands. For this, you can use a special command with an emotional name - OOPS.
ACADACLT
17.8.2010   17543×
this tip shared by ARKANCE experts applies to: ACAD · ACLT ·
Tip 15138:AutoCAD Field formatting codes - full list.
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15059:Undocumented drawing variables in Autodesk Fusion.
Tip 14991:Changing the order of rows in a table - sorting tables in AutoCAD.
Tip 14877:AutoCAD reports "U command disabled." My UNDO doesn't work.
Back    All CAD Tips
Categ:
