Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8921:
Question
The Windows component for synchonization of documents and settings with the Autodesk 360 cloud service runs in the Windows system tray. If there are problems with this component (reports synchronization erros), try to apply the "Autodesk Sync 2013 Service Pack 1" (see Download).
If you want - for any reason - to completely disable this resident process (adsync.exe), don't just "kill" it in the Task Manager. Use the Windows tool "System configuration" instead.
With appropriate rights, run the Windows utility MSCONFIG, in the "System configuration" dialog go to the "Startup" tab and uncheck the option at the line "Autodesk Windows Components":
and restart system.
You can re-enable this tool anytime again (msconfig displays the date of switch-off).
ACAD2013ACLT2013Inv2013Revit2013
19.11.2012    44692×
Tip 14310:Easy graphical display of the project or assembly file structure (hidden function).
Tip 13844:With which subscriptions do I get Autodesk Drive cloud storage as a bonus?
Tip 13459:DWG drawing version history directly in AutoCAD.
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 12667:How to free up space in the local cache of Desktop Connector?
Back    All CAD Tips
Categ:
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
