  Visitors: 2508
CAD tip CAD tip # 13197:
How to transfer a model or sketch parameter to iProperties?
A - answer In the dialog Parameters, at my new custom parameter (from a sketch), the option for exporting it as external is missing - how to get it now to the document's iProperties?
Custom parameter
The solution is simple - with a single line iLogic macro you can copy the value of your custom parameter Cislo_znacky (tag number) to a custom property:
iProperties.Value("Custom", "Cislo_znacky") = Cislo_znacky
And the resulting iProperty value:
Then run this iLogic rule automatically at the appropriate time (on an event), e.g. before saving.
NOTE: you can also nest the command into a "try-catch" construction to avoid any errors
Inventor
22.1.2022    20314×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13911:How to print all sheets at once from Inventor?
Tip 13852:How to bulk-update all model parameters?
Tip 13836:How to reset view numbering in Inventor?
Tip 13744:Simple password protection of Inventor documents (iLogic).
Tip 12508:How to assign an expression (not value) to a user parameter with iLogic?
