  Visitors: 6185
CAD tip CAD tip # 14045:
In my AutoCAD script file (.SCR) I cannot enter a name containing a space.
A - answer In AutoCAD, you can use spaces in all prompts for name (filename, folder, layer, dimension, style, font).
However, if you enter a name at the prompt in a commandline version of a command from a running script (.SCR), the space in the name is interpreted as an end-of-line, new line, Enter.
If you need to use a space in a name entered through a script, enter the name enclosed in double-quotes, i.e. "my name" - e.g. "C:\My folder\My file.dwg" or "My layer" or "My font".
Check also your setting of the EXTNAMES variable (should be 1).
This tip applies both to script files run through the command SCRIPT, and to scripts entered through AutoCAD or AutoCAD LT runstrings, and also to scripts used in the AcCoreConsole.exe console.
ACADACLTADTACADMPlantMapCivil3D
27.2.2024    13634×
Tip 14080:AutoCAD 2025 is not displaying some fonts correctly.
Tip 14006:Universal MsgBox in AutoLISP.
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12609:Dynamo - how to convert a raster photo to 3D model in Revit?
