CAD tip CAD tip # 8225:
Question
The project coordination application Autodesk Navisworks offers not only direct support for Autodesk products but also support of project data from other CAD applications and file formats.
The format NWC (NavisWorks Cache) is used for export of 3D geometry and the associated attribute metadata from non-Autodesk applications. Export of NWC files from other different types of applications is provided by a separate module "NWC Exporter" (see DL Download), which contains native plug-in modules for 32-bit and 64-bit versions of Autodesk software, for ArchiCAD (9-13), 3ds Max (8-2012), 3ds Max Design (2010-2012), VIZ (2007-2008), Microstation (8, 8i, 9, J).
So it is possible in Navisworks 2012 to combine, analyze and present project data from these applications along with CAD and BIM models AutoCAD, Revit, 3D Plant, Civil 3D, with 3D point clouds and other documents.
NW2012
22.9.2011   9376×
this tip shared by ARKANCE experts applies to: Navisworks 2012 ·
Tip 15045:Which cloud projects are available in the Autodesk Forma mobile app?
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14957:Controlling Navisworks from the runstring.
Tip 14799:7 quick methods to upload your project to Autodesk Docs (Forma Data Management)
Tip 14705:What is the difference between Data Exchange Connector and import/export support for a given CAD/BIM format?
Back    All CAD Tips
Categ:
