CAD tip CAD tip # 8151:
Question
Most of the keyboard shortcuts defined in AutoCAD for Mac (and AutoCAD LT for Mac) are the same as the standard hotkeys in AutoCAD for Windows (see the overview). But some "hot keys" are defined differently in AutoCAD for MacIntosh:
⌘1 - open/close the Tool Sets palette
⌘2 - open/close the Content palette
⌘3 - open/close the command window
⌘4 - open/close the Layers palette
⌘5 - open/close the Properties Inspector palette
⌘6 - toggles the status bar
⌘7 - open/close the Reference Manager palette
⌘8 - open/close the Material Browser palette
⌘/ - launches the online help (browser)
⌘E - displays the Export Data dialog
⌘F - displays the Find and Replace dialog
⌘G - groups selected objects
⌘I - displays the Properties Inspector palette
⌘R - regenerates the current viewport
⌘W - closes the current drawing
⌘+ - zoom-in 2x
⌘- - zoom-out 0.5x
⌘, - displays the Application Preferences dialog
⌘. - displays the Quick View dialog
Shift⌘C (Shift-Cmd-C) - displays the color palette
Shift⌘; (Shift-Cmd-;) - displays the Check Spelling dialog
ACAD2012ACLT2012
100% MacOSCAD
19.8.2011   36790×
this tip shared by ARKANCE experts applies to: AutoCAD 2012 · AutoCAD LT 2012 ·
Tip 15073:How to run an iLogic rule from the ribbon or with a keyboard shortcut?
Tip 14846:Do you know how to set camera FOV in Fusion's perspective view?
Tip 14815:Dynamic switching of the Fusion color theme according to Windows.
Tip 14782:Command line in Autodesk Fusion.
Tip 14772:Keyboard shortcuts in Autodesk Forma Site Design.
Back    All CAD Tips
Categ:
