CAD tip # 13288:
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Mechanical · AutoCAD Plant 3D · AutoCAD Map 3D · Civil 3D 3D · |
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
Tip 13855: | DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder. |
Tip 13688: | How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...) |
Tip 13442: | How to easily count the number of certain objects in a DWG drawing in AutoCAD LT? |
Tip 12215: | How to change truecolor DWG objects to indexed ACI colors? |
How to replace a 3D mesh model with a grid structure?
Automatic label - number of blocks in the specified area of a DWG. « | » Markup assistant with intelligent character recognition.
