New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11146:
Question
AutoCAD offers default dashed linetypes in its linetype library for imperial and metric drawings and a couple of complex linetypes with symbols.
Bur these basic linetype definitions do not use standard scale of 1:1 and do not conform to the European standard DIN EN ISO 128-2 (dash spacing).
To use standard ISO linetype definitions, easily applicable not only in the 1:1 scale but through LTSCALE also in related decimal scales (1:20, 1:50, 1:100...), you can employ the extended linetype library "ISO-LIN", available for download here in the Download section or from Download. The library was created by Ivo Kleparnik.
This library also contains another .LIN file with a large library of linetypes for utility drawings (the CSN 01 3411 standard). It contains as many as 933 different complex linetypes. The files ACADISO.LIN and acad_SIT_CSN.LIN (with its accompanying SHX shape file) should be copied into one of AutoCAD or AutoCAD LT support folders and then loaded into your drawing with the LTYPE command.
The new, standard-compliant metric linetypes can be identified by the "m" suffix - e.g.:
*BORDERX2_m,Hranicni_m (2x) ____  ____  .  ____  ____  .  ___
A,6,-3,6,-3,0.5,-3
*CENTER_m,Stredova_m ____ _ ____ _ ____ _ ____ _ ____ _ ____
Examples of complex linetypes from this library:
ACADACLTCivilMapADT
23.10.2016    38016×   FAQ
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14386:Visual catalog of blocks defined in a DWG drawing.
Tip 14230:How to transfer layer properties from another DWG drawing?
Tip 14223:Arithmetic operations for renaming blocks, levels, layouts...
Tip 14154:How to add directional arrows to 3D polyline linetype and to spline?
Back    All CAD Tips
Categ:
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
