CAD tip CAD tip # 6686:
Question
AutoCAD or other Autodesk product fails on installation or on the first run with the Error 1325.
This is a MSI installer error appearing on user accounts with names containing a dot (".") or with names longer than 11 characters. Users' login names probably have a period in their usernames - i.e.: "first.last".
What to do:
Install your CAD product in the Administrator account and then copy the Registry entries (HKEY_CURRENT_USER\Software\Autodesk) and the folders c:\Users\[username]\AppData\Local\Autodesk and c:\Users\[username]\AppData\Roaming\Autodesk.
ACADInventorRevitmax
20.5.2009   46342×   Expert
this tip shared by ARKANCE experts applies to: AutoCAD · Inventor · Revit · 3ds Max ·
Tip 14941:Fusion: The code execution cannot proceed because Qt6Widgets.dll or acge230.dll was not found.
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14695:Beware of Windows Update - AutoCAD suddenly requires an Administrator login on launch.
Tip 14328:How to verify entitlement of an application from Autodesk Apps using LISP?
Tip 14323:AutoCAD does not start, saved DWGs are sometimes corrupted, fatal error during export or copy, or missing NLS file.
Back    All CAD Tips
Categ:
