New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 10139:
Question
The freeware application CADstudio UnitsConversion is an add-on tool palette for AutoCAD 2014, 2015 and higher. This tool performs conversion of hundreds of internetional and historical physical units - length, area, volume, force, temperature, time, speed, density, force, moments, energy, acceleration, or numerical systems (binary, hex, roman...).
The command palette uses the interactive online units converter from www.cadforum.cz/cadforum_en/units.asp directly in AutoCAD user environment. You can display this palette using the command CONVERTUNITS or with the icon "Convert Units" in the ribbon Add-ins.
You can install the application easily through Exchange Apps, or alternatively by unpacking the downloaded ZIP archive (the app .bundle) to the folder:
C:\Users\{USERNAME}\AppData\Roaming\Autodesk\ApplicationPlugins\
or:
C:\ProgramData\Autodesk\ApplicationPlugins\
Download UnitsConversion from Download
ACAD2016ACAD2015ACAD2014
15.12.2014    13337×
applies to: AutoCAD 2016 · AutoCAD 2015 · AutoCAD 2014 ·
Tip 13965:Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic)
Tip 13923:Resetting the Data Panel in Autodesk Fusion.
Tip 13228:DWG or DXF file exported to/from Fusion 360 has incorrect size (scale, 10x larger/smaller).
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 13013:Converting a 3D mesh to a 3D solid in Fusion 360.
Back    All CAD Tips
Categ:
