CAD tip CAD tip # 8962:
Question
With the freeware utility CADstudio SphereProj you can project any 2D curve (polyline, spline, arc, line) or a group of curves to a spherical 3D surface.
The add-in application SphereProj can be downloaded - like the other CAD Studio's freeware tools - from DL Download. Load it with APPLOAD and the run the SphereProj command. After you enter the sphere radius, the command marks a rectangular area that will be projected to the sphere (at 0,0,0). Any curve drawn in this area can be be transferred (projected) to the sphere surface (the horizontal axis of the rectangle will become the "equator" on the sphere, its upper and lower edges will become the north a south "poles"). The 3D projection respects the color of the original 2D curve. You can specify the precision of the conversion - the number of segments that the original curve(s) will be divided to.
If you want to project a text, convert it first to to lines - see the tip 1901. Projection of geometrical entities to an arbitrary 3D surface is described in the tip 7297.
ACAD
9.12.2012   13479×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 15063:How do I convert the geometry of a Civil pipe network to 2D, or to SHP format?
Tip 15049:Inventor displays incorrect dimension lengths in my drawing views.
Tip 15045:Which cloud projects are available in the Autodesk Forma mobile app?
Tip 15040:Autodesk Flex Token Calculator - "Pay-as-you-go" pricing for licenses and services.
Tip 14998:What is the difference between two open documents, two open Inventors, and two Inventors on two different PCs?
Back    All CAD Tips
Categ:
