CAD tip CAD tip # 7852:
Question
If you want to import aerial images from Google Earth into your projects, you can use the somehow limited functionality included directly in AutoCAD Civil 3D.
But if you need to perform this and many other functions much more conveniently, more precisely, much faster and in full resolution, you can use the add-on application Plex.Earth Tools by Plexscape. This tool allow to use the Google Earth data not only in Civil 3D but in all versions of AutoCAD - i.e. also in AutoCAD Architecture.
GE map in AutoCAD
Plex.Earth Tools is a simple to use add-on application which automatically inserts the whole mosaic of aligned, tiled color maps covering the complete area of your project - in a single step, on one click. You can specify a polygon to cover (with overlaps) or a buffer-zone (bands) along a corridor (roads, rivers, etc.). Plex.Earth understands over 2.500 regional coordinate systems so you can keep your project in a standard setup.
You can also use this software in the opposite way - to publish your CAD models directly to Google Earth. The latest version of PlexEarth supports also importing 3D terrains from GE to AutoCAD DWGs (digital terrain models) including contour lines.
Thanks to the support of WMS data sources in Google Earth (overlay) you can use it also to insert other types of GIS and cadastral data from online WMS resources. Google Earths acts as a middleware application in this case (see WMS details - in Czech).
You can find more information, including videos on the Plex.Earth page.
ACADADTCivilMap
11.3.2011   124235×   FAQ
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD Architecture · Civil 3D · AutoCAD Map 3D ·
Tip 14808:How to import a KML/KMZ file from Google Maps, including placemark labels, into AutoCAD Map 3D?
Tip 14468:How to connect Bing Maps in AutoCAD 2026 (and higher)?
Tip 13971:What do geolocation codes like 8FWPXFCF+82 or 33UVQ61402434 mean?
Tip 13512:How to open Google Earth directly in your AutoCAD window?
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Back    All CAD Tips
Categ:
