  Visitors: 7394
CAD tip CAD tip # 12685:
ReLinkField - re-link fields to source objects.
A - answer Let's assume you have a DWG drawing with automatic fields, texts or block attributes linking to a specific geometric properties of selected objects (i.e. fields with the Object option). If you now delete the source objects, the dynamic value of the field will lose its link and the field will display only as "######".
With the freeware LISP utility ReLinkField (RLF) you can restore the lost links. If you create a new control object of the same type or if you want to point your dynamic label to a different, existing object of the same type, just type the command RLF, select the label object (text, block) and then select the new source object. You can perform this "link redirection" also on standard, functional links, not only on those broken, lost ones. Neither the display format nor the property type will be changed in the fixed relation link.
An example of such links - different types of labels showing the radius values linked to circle objects. The dependency links are displayed using the FieldLink utility.
You can download the ReLinkField utility from Download and load its VLX file to your AutoCAD using the APPLOAD command.
A sample drawing - see RLF.DWG in the Block library.
ACAD
28.7.2020    11784×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Tip 13996:Automatic hide for Revit palettes - save screen space (undocumented).
Tip 13788:Green square - mathematical charade and parametric constraints in AutoCAD.
Tip 13760:Parametric text content in Fusion 360 sketches (and models).
Tip 13740:Dynamic label with filesize of the current DWG file.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
