New CADforum look launched.
Over 1.084.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 10340:
Question
Since versions 2015, Autodesk applications use a common engine for translation of foreign CAD formats. The ATF engine (Autodesk Translation Framework) is used also in 3ds Max 2016, and so it newly supports also loading and rendering or animating of assemblies in non-Autodesk CAD file formats, e.g. from CATIA or SolidWorks. You don't need to have the particular CAD application installed.
See e.g. the sample fan assembly from CATIA V5 loaded into 3ds Max:
max2016
28.5.2015    14817×
applies to: 3ds Max 2016 ·
Tip 14183:PLKangles - display/check kink angles in polylines.
Tip 13911:How to print all sheets at once from Inventor?
Tip 13844:With which subscriptions do I get Autodesk Drive cloud storage as a bonus?
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13541:Using Twinmotion from Revit to visualize other types of 3D scenes.
Back    All CAD Tips
Categ:
