New CADforum look launched.
Over 1.085.000 registered users (EN+CZ). Try the new Engineering calculator, the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
CAD tip # 10972:
Question
With the freeware aplication FLD2TXT you can globally replace dynamic text fields in your drawing with static text strings representing their current values.
Download this CAD Studio's utility from Download, load it with APPLOAD and type the command FLD2TXT. You can choose whether to proces just the modelspace fields, paperspace fileds, or all of them.
This tool converts standalone fields, fields in MTexts and Multileaders, in Dimensions and in block Attributes.
ACAD
20.6.2016
8910×
applies to: AutoCAD ·
