  Visitors: 7134
CAD tip CAD tip # 9538:
Revit installation hangs at "Preparing Revit Content".
A - answer During Revit installation, the installer "hangs" at the step "Preparing Revit Content".
If you are installing from the downloaded version of Revit and you have choosen to install the content (libraries), Revit needs to download these libraries from the internet during the installation. If the installer does not get the internet connection for some reason (firewall, antivirus, disconnected, MSIE security settings), the installation will "hang".
Try to add *.autodesk.com to the list of trusted sites in Internet Explorer and retry the installation from the Administrator account.
Also check the libraries you are installing. If you select all available national libraries, the installer will download about 15 GB of data, which could take some time - depending on your connectivity (and so the installation may appear as "hanging"). Limit the downloaded content only to neccessary libraries.
Revit2014Revit2013
11.11.2013    23002×
Prices - CAD eShop:
applies to: Revit 2014 · Revit 2013 ·
Tip 13988:How do I uninstall hotfixes, updates and apps that cannot be uninstalled via Control Panel?
Tip 13917:Check for concurrently running named licenses (device limit).
Tip 13633:How to run Revit, Inventor or Windows version of AutoCAD on macOS?
Tip 13541:Using Twinmotion from Revit to visualize other types of 3D scenes.
Tip 13539:Revit 2023.1 shows "Twinmotion is not installed"
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
