CAD tip CAD tip # 7241:
Question
If you need to find a specific text (string) in an AutoCAD drawing and you are using AutoCAD, AutoCAD LT or other application based on AutoCAD, the situation is simple - just use the command FIND.
But if you are only a "consumer" of a DWG drawing and you have not available the AutoCAD license, the situation is more complicated. The drawing text search function is included in the free CAD viewer Autodesk Design Review. This program can process drawings in the DWF, DWFx and also DWG and DGN formats. So you can use its function (button) Find in the ribbon Home > Search and enter the searched text. The Find panel lists all occurrences of the searched text in the drawing (in its text entities, drawing properties, titles, etc.). Double-click on the individual items in the list to zoom to the specific occurrence of the searched text.
Search text in DWF
Due to the way of conversion (publishing) of the DWG drawings to DWF, you can search only texts written in a TrueType font (not SHX - they are published as vectors).
To look-up a specific text in a group of drawings you can use e.g. the srxText utility or the indexed contents of DWG drawings stored in the document-management application iProject.
DWFDWFACADiProject
7.3.2010   51067×
this tip shared by ARKANCE experts applies to: DWF · DWF · ACAD · iProject ·
Tip 14911:Using symbolic variables to enter repeated values in AutoCAD.
Tip 14527:Search/Replace texts in Inventor drawings - iLogic.
Tip 14431:What are the AutoCAD commands -FIND, FINDMATCH and FINDINCLUDE?
Tip 14163:How to select DWG texts containing a certain number of characters?
Tip 13749:How to add the SEARCH/REPLACE command into AutoCAD Web?
Back    All CAD Tips
Categ:
