CAD tip CAD tip # 8642:
Question
Generated documentation views on 3D models behave differently than standard paperspace (layout) viewports. To assign scale not listed in the scale list (e.g. 1:250) you need to add this scale to the list using the SCALELISTEDIT command. Another option is to set the non-standard scale ("Custom") using the VIEWEDIT command (its Scale option) - use mouse double-click on the viewport.
Standard scales can be conveniently assigned from the context ribbon when you double-click on the viewport:
ACAD2013Plant2013ACADE2013
21.5.2012   21818×
this tip shared by ARKANCE experts applies to: AutoCAD 2013 · AutoCAD Plant 3D 2013 · AutoCAD Electrical 2013 ·
Tip 14958:A PDF drawing from Revit or AutoCAD does not print exactly at a 1:1 scale.
Tip 14709:How to export Fusion drawings to AutoCAD (DWG)?
Tip 14321:How to re-dock a dragged model-tree browser window in Fusion?
Tip 14310:Easy graphical display of the project or assembly file structure (hidden function).
Tip 13719:How to load a 2D DWG drawing of a part into Fusion 360?
Back    All CAD Tips
Categ:
