New CADforum look launched.
Over 1.085.000 registered users (EN+CZ). Try the new Engineering calculator, the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
CAD tip # 7965:
Question
With the LISP utility CADstudio SlopeTick you can easily create terrain slope lines (ticks) in AutoCAD:
There is a similar function (automatic) in AutoCAD Civil 3D, or you can use the dynamic block Terrain slope (by zdrk).
You can download the SlopeTick free utility from Download
Since version 1.4 you can set the size of shorter lines with the LISP variable slopetickshort - e.g.: (setq slopetickshort 0.33)
ACADCivilADTMap
![100%](../common/cf1.gif)
![](../common/cf0.gif)
9.5.2011
74028×
