CAD tip CAD tip # 7109:
Question
Turbo Our customers are often facing a problem where AutoCAD suddenly works slower, with longer response times or jumpy cursor. This is usually caused by the content of the current drawing (see tips) but the reason may by also in your current AutoCAD settings (its system variables).
For these situations we have developed a small LISP utility - TURBO. This tool reveals the possible internal reasons of performance problems. Its command TURBO will switch AutoCAD (2026-2007, any vertical version, even AutoCAD LT 2024+) to a faster mode by presetting all relevant system variables. The next TURBO command then switches AutoCAD back to its original status (your former settings).
The performance differences depend on your current settings, on the complexity of your drawing and on the PC configuration. You can expect maximum "Turbo" effects on slow PCs with poor existing settings and in emulated/virtualized environments.
The active "Turbo" mode is indicated by red commandline text and by the "[TURBO]" indicator in the status line. Return back to "normal" mode in the same session to restore the original settings (or use Turbo0 for reset). You can also add your own settings to make AutoCAD work faster.
You can download the TURBO utility from DL Download. Load the VLX file with APPLOAD any type the TURBO command. See more information in the attached Readme file.
ACAD2026ACAD2022ACAD2016ACAD2010ACAD2008ACADLT
14.12.2009   45194×   FAQ
this tip shared by ARKANCE experts applies to: AutoCAD 2026 · AutoCAD 2022 · AutoCAD 2016 · AutoCAD 2010 · AutoCAD 2008 · ACADLT ·
Tip 15113:Faster startup of AutoCAD 2027 products.
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14826:AutoCAD runs slower on a laptop docked in a docking station.
Tip 14782:Command line in Autodesk Fusion.
Back    All CAD Tips
Categ:
