New CADforum look launched.
Over 1.085.000 registered users (EN+CZ). Try the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
CAD tip CAD tip # 9136:
Question
If you want to change the language of user environment in the Inventor Content Center (CC), you can just modify the loading control file for this add-in.
Use Notepad to add (or edit) a line in the file Autodesk.ContentCenter.Inventor.addin stored in the folder C:\Users\YOURUSERNAME\AppData\Roaming\Autodesk\Inventor 2013\Addins\ as:
<Language _OVERRIDDEN_="ADDED" CCLanguageOverride="de-DE"></Language>
resp.
<Language _OVERRIDDEN_="ADDED" CCLanguageOverride="en-US"></Language>
The language setting can be switched to any value supported in all localized versions of Autodesk Inventor, so you can choose also more exotic languages like cs-CZ (Czech), hu-HU (Hungarian) or zh-CN (Chinese):
Hungarian CC
Inv2013Inv2012
11.3.2013    7929×
applies to: Inventor 2013 · Inventor 2012 ·
Tip 13791:Part number from the Frame Generator is not transferred to the Part Number iProperty.
Tip 12893:"Publish is not Successful" when editing a family in Content Center.
Tip 12532:Error when inserting standard part - Modeling: Failed to insert a part into assembly!
Tip 12412:Missing category icons and thumbnails in Inventor Content Center.
Tip 12317:How to publish a custom iPart to CC with Color as one of its parameters?
Back    All CAD Tips
Categ:
