  Visitors: 6263
CAD tip CAD tip # 13566:
Text size in Revit temporary dimensions.
A - answer If you find that all temporary, interactive, or dynamic dimensions in Revit appear too small or too large, including the displayed distances measured with Measure between two references, you can change the font size of the displayed dimensions - see the option:
File > Options > Graphics > Temporary dimension text appearance > Size
In addition to the size, you can also affect the background mask (opacity of the buffer area).
In older versions of Revit, you can use the setting in the .INI file, see Tip 5730 (CZ).
Revit
9.12.2022    11375×
Prices - CAD eShop:
applies to: Revit ·
Tip 14041:Displaying the dimensions of equal repeated segments in Revit (EQ).
Tip 13692:What is the precision in Revit?
Tip 13012:Why Revit doesn't display temporary dimensions when inserting windows or doors?
Tip 12997:Hiding Revit dimensions smaller than...
Tip 12777:Arithmetic and trigonometric functions available in Revit expressions.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
