New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
Place your Ad on CADforum.cz
CAD tip CAD tip # 9781:
Question
Just after the installation of Revit 2015, the update manager tool "Autodesk Application Manager" reports availability of the "Revit 2015 Update Release 1". Should I install it?
Yes, it is an early update version for Revit 2015. It updates the distrubution (FCS) build 20140223_15 with a new build (UR1) 2140322_1515. Just click the Install button.
See also the overview of service packs.
Revit2015ACADInvCivil
14.4.2014    7441×
applies to: Revit 2015 · AutoCAD · Inventor · Civil 3D ·
Tip 14349:12 free material texture libraries for PBR rendering.
Tip 13404:How to import an IFC file in AutoCAD?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13152:Compatibility of Autodesk products with Windows 11.
Tip 13012:Why Revit doesn't display temporary dimensions when inserting windows or doors?
Back    All CAD Tips
Categ:
