CAD tip CAD tip # 10383:
Question
There are various algorithms to find the shortest path between two points on a given interconnected network (pipes, communication, roads, etc.).
In AutoCAD Map, you can effeciently solve this task using topologies (including throughput parameters, asymmetry, penalty functions). In plain AutoCAD, you can find the shortest connection between 2 network nodes using the freeware LISP utility CADstudio SPath.
Download the SPath.vlx file from DL Download, load it into AutoCAD with APPLOAD and type the SPATH command. Select the lines and polylines defining the network and pick two node-points on this network (precisely, use osnap). SPath will compute and generate a red polyline of the shortest path copying segments and nodes on the given network. Adjacent segment nodes must match. The number of selected network segments directly influences computing time of the optimal path.
Example of using SPath on a road network map of the Czech Republic - from the DWG block SilniceTematicky:
see also YouTube
To generate the shortest path connecting multiple points, use the ShortPath utility (travelling salesman problem, TSP).
(original algorithm: H.Schröder)
ACAD
30.6.2015   16560×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 14436:Conversion of arc polylines to straight-segment polylines (e.g. for GIS).
Tip 10416:How to fix/repair large 3D mesh models?
Tip 10128:How to convert a line-based map to closed polygons (lots)?
Tip 10102:How to simplify a complex 3D mesh model?
Tip 4068:How to find the polyline direction/orientation?
Back    All CAD Tips
Categ:
