CAD tip # 7654:
Tip 13597: | How to convert RGB color to Pantone, RAL, AutoCAD ACI, CMYK or vice versa? |
Tip 13557: | How to create an image with transparent background in Fusion 360? |
Tip 12847: | How to make transparent mask for raster maps in Autodesk Infraworks? |
Tip 12361: | Seamlessly connected images by irregular clipping in AutoCAD (or LT). |
Tip 12214: | How to set bitmap transparency in an Inventor drawing. |
Section modulus of 2D profiles in AutoCAD.
Extract hatch patterns to PAT files - copy hatches between DWGs. « | » 3D scene renders as a black screen only.
