  Visitors: 6532
CAD tip CAD tip # 12101:
Timing of any AutoCAD command - CMDtimer.
A - answer With the freeware utility CMDtimer you can easily measure execution time of any native AutoCAD command.
Just download the LISP-Reactor CMDtimer from Download, load it into AutoCAD with APPLOAD and run it by typing the command CMDTIMER (repeated command disables it again - acts as a toggle).
The any AutoCAD command simply displays a report (on the command line) about the execution time of that command - e.g.:
CMDtimer> REGEN: 0.531 secs (1798366440 ticks)
It lists the total time in seconds and the exact number of CPU "ticks". In this way you can easily measure the influence of different display settings, fonts or simplified geometry, especially on large drawings (benchmarks).
Of course in interactive commands, the total run time is counted, including the user response time, answering the command prompts. To measure performance, use scripts or macros in this case.
ACADCivilADTPlant
3.1.2019    13918×
Tip 11433:Should I use Win10 Game Mode for my AutoCAD, Inventor or Revit?
Tip 5910:Undocumented benchmark utility installed with AutoCAD.
Tip 5268:Make your AutoCAD faster on nVidia Quadro cards
Tip 3631:Make your 3ds max about 74% (up to 134%) faster!
Tip 2655:How to run standard benchmark procedures to show the PC performance in AutoCAD?
