CAD tip # 7018:
applies to: Revit 2010 · Revit 2009 · |
Tip 13996: | Automatic hide for Revit palettes - save screen space (undocumented). |
Tip 13227: | Reference Explorer - quick analysis of your project or assembly (file size, xref errors). |
Tip 11581: | How to compare changes between two versions of a Revit BIM project? |
Tip 9842: | Interactive cloud viewer for 3D CAD data in Autodesk 360. |
Tip 9602: | Do you know how to customize your QAT panel? |
You may want to convert the solid to a Brep.
