CAD tip # 12988:
applies to: Infraworks · |
Tip 13873: | How to load GeoJSON data into AutoCAD, Map, Civil 3D, Infraworks? |
Tip 13402: | Which products and features can I use for free with Flex Token licensing? |
Tip 12847: | How to make transparent mask for raster maps in Autodesk Infraworks? |
Tip 12779: | How to export a hi-res image from Autodesk Infraworks? |
Tip 12663: | How to transfer my project from Infraworks to Revit? |
An image inserted in Map is not georeferenced.
In the dark Inventor environment, contrasting edges are not displayed. « | » Easily find CAD/BIM document references (including missing ones) - Reference Explorer
