  Visitors: 8549
CAD tip CAD tip # 12297:
Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
A - answer The Autodesk Manufacturing Data Exchange Utility (AMDEU) is a data translation tool in the CAM products of the Delcam family. It handles import of all types of 3D CAD data into PowerMill, FeatureCAM, PowerShape. It installs automatically with all these CAM applications and if a 3D model is imported, it starts in the background, performs the required conversion and then terminates itself.
The Autodesk Manufacturing Data Exchange tool supports import from the following CAD formats (precise info about the format versions and entity types supported can be found in the product Help):
  • 3MF
  • ACIS
  • Alias
  • AMF
  • ASCON
  • AutoCAD
  • CATIA
  • Cimatron Elite
  • Cimatron
  • Creo
  • DDX
  • Autodesk DGK
  • Autodesk DMT
  • Geomagic
  • I-DEAS
  • IGES
  • Inventor
  • JT
  • Parasolid
  • PDF
  • PLY
  • PowerShape Parts
  • Pro/Engineer
  • Rhino
  • Shining3D
  • Autodesk ASM
  • Solid Edge
  • SolidWorks
  • SpaceClaim
  • STEP
  • STL
  • TopSolid
  • U3D
  • Unigraphics
  • VDA-FS
  • Wavefront Obj
  • WinMAX
E.g. the version MDEU 2020 has added support of these versions of the above mentioned CAD formats:
  • Alias 2019/2020
  • Autodesk ASM 2500
  • SolidEdge 2019
  • SolidWorks 2019
  • Cimatron Elite 14
  • ACIS 27 and 28
  • Rhino 6
  • JT 10.3 and 10.4 and 10.5
  • CATIA 5 V5-6R2019 (R29)
  • Creo 6
  • Parasolid 31.1
  • NX Continuous Release 1847 and 1872
Version 2022 has added the following formats:
  • Creo 8.0
  • CATIA V5-6R2021
  • JT 10.6
  • NX Continuous Release 1953-1980
  • Rhino 7, inc. SubD
  • Solid Edge 2021
  • SolidWorks 2021
Version 2023 has added the following formats:
  • NX 2007
  • Inventor 2023
Version 2023.03 (ATF 11.15.0) has added the formats:
  • Alias 2022
  • Creo 9.0
  • CATIA V5-6R2022
Version 2023.04 (ATF 11.22.0) has added the formats:
  • Alias 2023
  • NX 2206
  • JT up to 10.8
  • Parasolid 34
See also CAD formats
PowerMillFeatureCAMPowerShape
100% *  CAD,CAM
2.7.2019    24706×
Prices - CAD eShop:
applies to: PowerMill · FeatureCAM · PowerShape ·
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
Tip 13152:Compatibility of Autodesk products with Windows 11.
Tip 12880:How to import Parasolid 33 files into PowerMill?
Tip 12341:Check collisions of the machined model with the CNC machine.
Tip 11959:Supported file types (applications) with reference detection in Autodesk Desktop Connector.
