CAD tip # 13967:
applies to: AutoCAD · AutoCAD LT 2024 · AutoCAD Architecture · AutoCAD Mechanical · AutoCAD Plant 3D · AutoCAD Map 3D · Civil 3D 3D · |
Tip 13653: | FPoly - draw fixed-length polylines in AutoCAD. |
Tip 13615: | Associative angle bisector in an AutoCAD DWG drawing. |
Tip 13163: | Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD) |
Tip 12526: | BufZone - buffer zones and wipeouts around AutoCAD line objects. |
Import Excel table by snapping a photo of it.
What do geolocation codes like 8FWPXFCF+82 or 33UVQ61402434 mean? « | » Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic)
