  Visitors: 3885
CAD tip CAD tip # 13468:
How to change the drawing background color in AutoCAD Web? (black drawing)
A - answer Even in the AutoCAD Web version you can set the color of UI elements. For this, use the respective environment variables.
For example, the Background variable is used to set the background color of the model space. The Layout background variable is used to set the background color of the paper (layout).
You set the color hue using a numeric string. Its value can be calculated using the formula:
(blue * 65536) + (green * 256) + red
You can use the LISP function (setenv) to set this. Type this function (including parameters) to the AutoCAD Web command line. The names of variables must be specified exactly, including upper/lower case letters. The numeric color code is a string, i.e. in double-quotes.
An example of setting the background color of the model (green):
(setenv "Background" "1111111")
An example of setting the background color of a layout (black):
(setenv "Layout background" "0")
The color change happens instantly, no need to restart the AutoCAD session. The color settings are remembered, even between drawings/sessions. To return to the default settings, use the default color hues for the model: "3156001" and for the layout: "16777215".
You can also automate the background-color toggle by using the freeware BW.LSP utility for AutoCAD Web. Download it from Download and using the LISP function load it for autoloading in your AutoCAD Web. This one-time operation will add a new command "BW" to your AutoCAD. Then anytime type the BW command on the AutoCAD command line to toggle both your model- and layout-background color - see:
ACADweb
9.9.2022    25497×
Prices - CAD eShop:
applies to: ACADweb ·
Tip 14063:How to get week day and week number from a given date.
Tip 14006:Universal MsgBox in AutoLISP.
Tip 13933:How to set grid colors in AutoCAD Web?
Tip 13920:Saving your Inventor model in the presentation color scheme (iLogic).
Tip 13884:How to send e-mails with an iLogic macro?
LogOff 2006 More info
