CAD tip # 12242:
applies to: Inventor 2020 · |
Tip 13920: | Saving your Inventor model in the presentation color scheme (iLogic). |
Tip 13791: | Part number from the Frame Generator is not transferred to the Part Number iProperty. |
Tip 12326: | How to customize your Fusion 360 background color? (any color theme) |
Tip 12152: | Sketch lines linewidth - how to make Inventor lines thicker for a 4K display? |
Tip 10596: | Changing colors of the Inventor color schemes (UI). |
Product codes (registry) of Autodesk CAD applications.
How to remove fillet or chamfer from a 3D solid? « | » How to extract isolines from a surface of a 3D object?
