CAD tip # 11122:
applies to: Inventor · |
Tip 13824: | How to export OBJ including materials, textures from Inventor? |
Tip 13805: | Projecting/embossing a profile on a curved surface in Fusion 360. |
Tip 13788: | Green square - mathematical charade and parametric constraints in AutoCAD. |
I have redlined a drawing in VoloView but I cannot see my markups when I open the drawing in AutoCAD.
How to convert lines forming a text to a text entity. « | » 3D PDF published from Inventor 2017 come out empty.
